Switch Engine provides support for ExtremeCloud IQ. Currently, device discovery, basic monitoring, and visibility into homogenous stacking are supported. Switch Engine also has the ability to configure an optional user-defined virtual router (VR) and address of the server for ExtremeCloud IQ agent to connect to. These values are used instead of any auto-detected values.
In addition, users can configure the IQ Agent HTTP Proxy server IP and port, and define the username and password, if required.
To configure a server VR, VLAN Management, or address, use the following command:
configure iqagent server [vr [[vr-name | none] | [ vr_name vlan vlan-name]] | ipaddress [fqdn | ip_address| none]]
To configure the HTTP proxy, use the following command:
configure iqagent http-proxy [ipaddress [fqdn | ip_address] port port_number | user user_name password [encrypted encrypted_password | password] | none]
You can enable or disable the IQ Agent with the following commands:
Important
Important
Disabling IQ Agent prevents all access to ExtremeCloud IQ. Any current activity with ExtremeCloud IQ, including remote SSH sessions, are disconnected immediately. Re-enabling IQ Agent can only occur by using the enable command by either console or Telnet or SSH access. Disabling IQ Agent deactivates automatic DHCP access on VLAN Mgmt, which is required for Zero-Touch Provisioning (ZTP).
enable iqagent
disable iqagent
To view information about IQ Agent, use the following command:
show iqagent discovery
For more information about ExtremeCloud IQ, go to https://www.extremenetworks.com/support/documentation/extremecloud-iq/.
Table 1. Supported Platforms
Switch Series Switch Models
4120*
4120-24MW-4Y
4120-48MW-4Y
4220*
4220-8X
4220-12P-4X
4220-12T-4X
4220-24P-4X
4220-24T-4X
4220-48P-4X
4220-48T-4X
4220-4MW-8P-4X
4220-4MW-20P-4X
4220-8MW-40P-4X
ExtremeSwitching 5320
5320-48T-8XE
5320-48P-8XE
5320-24T-8XE
5320-24P-8XE
5320-16P-4XE
5320-16P-4XE-DC
5320-24T-4X-XT
5320-24T-24S-4XE-XT
ExtremeSwitching 5420
5420F-8W-16P-4XE
5420F-24P-4XE
5420F-24S-4XE
5420F-24T-4XE
5420F-16MW-32P-4XE
5420F-16W-32P-4XE
5420F-48P-4XE
5420F-48P-4XL
5420F-48T-4XE
5420M-24T-4YE
5420M-24W-4YE
5420M-16MW-32P-4YE
5420M-48T-4YE
5420M-48W-4YE
ExtremeSwitching 5520
5520-24T
5520-24W
5520-48T
5520-48W
5520-12MW-36W
5520-24X
5520-48SE
5520-24T-ACDC-BASE
5520-48T-ACDC-BASE
5520-24X-ACDC-BASE
5520-48SE-ACDC-BASE
ExtremeSwitching 5720
5720-24MW
5720-24MXW
5720-48MW
5720-48MXW
Extreme 7520 7520-48Y-8C
7520-48XT-6C
7520-48YE-8CE
Extreme 7720 7720-32C
* - See 4000 Series User Guide for this version of Switch Engine for detailed information on these Cloud-managed devices.
IQ Agent and ExtremeCloud IQ Communication
After the IQ Agent is enabled, communication forms between the IQ Agent and extremecloudiq.com by secure HTTPS communication using destination TCP port 443. Communication between the IQ Agent and ExtremeCloud IQ occurs every 30 seconds, which includes check-in to ExtremeCloud IQ for actions, and includes CPU, memory, FDB information, Syslog, and ports statistics information. Note that data plane traffic is not sent to ExtremeCloud IQ by the IQ Agent.
Note that Telnet and SSH do not permit access to ‘hivemanager‘ account, which the IQ Agent creates for its own purpose and uses it for all cloud-initiated SSH connections through local host, so logging on to this account through Telnet or SSH is not allowed.
IQ Agents use SNMPv2 (enabled only for internal requests) to monitor the status of the switch.
Distributed Denial of Service Support for IQ Agent
Distributed Denial of Service (DDoS) support for IQ Agent installs a filter on HTTPS L4 ports to set a CPU queue (QoS 5) that separates IQ Agent traffic from other IP exceptions. This new ACL redirects TCP traffic with source port 443 (default HTTPS port) to CPU queue 5. The IQ Agent system ACL is installed or uninstalled along with the L3 Unicast Miss (L3UCMiss) filter.
Automation of this feature is supported on all Universal switches.
You can also manually install the ACL to redirect IQ Agent traffic to CPU queue 5 on smaller switches with 8 ACL slices by running the following command:
# configure access-list iqagent.pol any
iqagent.pol:
entry iqagent_cpu5 {
  if {
    protocol tcp;
    source-port 443;
  } then {
    traffic-queue cpu_q_5;
